Starter problems
Old Jan 27, 2010 | 09:22 PM
1quickz's Avatar
Default Starter problems
OK just replaced the starter on my 93z and it lasted about two days. for some reason the starter motor is staying on even after i shut the car off the first one burned up luckily didn't burn the hole car up. just put a new one one yesterday thinking is was just faulty but same thing but this time i was able to get the battery unhooked in time. i have no clue whats causing this any suggestions.
Old Jan 28, 2010 | 12:38 AM
RamAir95TA's Avatar
Check the terminals on the solenoid and make sure they aren't touching. You might have the purple wire grounded to 12v. Sounds like a cable/wire issue to me.
Old Jan 28, 2010 | 01:23 AM
the_merv's Avatar
Veteran: Air Force
Either the Wires on the Starter are touching, or the Ingnition Switch is messed up.
