help with shortblock combo for nitrous
Old Feb 8, 2010 | 12:38 PM
BRADP's Avatar
Default help with shortblock combo for nitrous
finally time to start ordering parts for the summer build. im looking for some suggestions on just about everything from pistons, rings, rods and anything. i know every car is going to be different but i just want to hear abt some healthy combos. car will see around a 250 to 300 shot through a plate and fogger. im already set on heads and cam will be custom when i decide on what cubes. open to any suggestions thank u
Old Feb 8, 2010 | 01:11 PM
RamAir95TA's Avatar
What is your budget and goals? What heads have you opted to go with? The more information you give, the more of an informed decision can be made.
Old Feb 8, 2010 | 02:32 PM
slomarao's Avatar
well we dont know how many cubes your looking at, so picking out a shortblock is going to be tough. Lend us a hand
Old Feb 8, 2010 | 05:00 PM
BRADP's Avatar
the heads are stock heads heavily ported with whole new valve train, cam will be a custom grind, single plane and a monoblade. im looking for any healthy combo whether it be a 355 383 or anything. i want to no what other people have gone with cube wise and what brands of crank pistons rods and that stuff and are making good power.
Old Feb 8, 2010 | 05:42 PM
RamAir95TA's Avatar
You still haven't answered the budget or goals question. A 355 and a 383 require two different approaches.
Old Feb 8, 2010 | 06:51 PM
BRADP's Avatar
2.5-3 g's
Old Feb 8, 2010 | 06:52 PM
96lt1m6's Avatar
come on Joe look into your crystal ball or rub the "secret decoder ring"
Old Feb 8, 2010 | 06:53 PM
RamAir95TA's Avatar
So you have 3k. Cool. What parts do you already have (i.e. what are you starting with?).
And you still have to answer the GOALS question. "Good power" doesn't give us much to go on.
Old Feb 8, 2010 | 07:07 PM
BRADP's Avatar
just need rotating assy. complete or piece it together. 6-700 hp on 2 kits
Old Feb 8, 2010 | 07:12 PM
slomarao's Avatar
I would contact the supporting vendors and see what they are offering. I would go 383, 6inch h beam rod, Nitrous forged piston(JE, Diamond, Ross). I would stay away from eagle and scat. Compstar, callies, lunati is what i would look into.
theres a guy running high 8's out of Iowa who has a LME 383(late model engine). I would give them a call. Pretty sure hes hitting a 350 shot.
Old Feb 8, 2010 | 07:23 PM
RamAir95TA's Avatar
700HP is nothing to sneeze at, and will easily cost you more than 3k to be done correctly. I don't for-see you doing the machine-work yourself. At that power level, you'll need a high quality forged crank (Callies or Cola is a good bet), good forged h-beam rods, good nitrous pistons (Diamond is arguably the best), and splayed four bolt mains (not totally necessary, but worth the peace of mind with that kind of power).
Basically what slomarao said is spot-on.
Old Feb 9, 2010 | 02:35 AM
97Z28SS's Avatar
Plus you'll want to half fill your block with hard block for added strength, you'll need almost double your budget. The proper forged rotating assembly will cost you $1500 _ $2000 plus the proper block maching, splayed billet caps, block filled will cost another $2000. Then you'll want to upgrade the oilpan/pump/pickup, ARP head/main studs, yada yada yada, it adds up really fast.
