help for fuel injectors
Old Feb 11, 2010 | 04:31 PM
6801's Avatar
Default help for fuel injectors
i bought the 30lbs svo ford injectors, is it a hard fit to get them to seat with fuel rail keps popping one side on then other pops of also on the stock lt1 fuel rail it has c retaing clips on the gm but the ford only have half slots and dont rotate right. with the clips on do i need them my part number is
fms-m-9593-bb302 from summit.
Old Feb 11, 2010 | 04:43 PM
bigj2717's Avatar
Make sure you put alittle bit of oil on the o-ring that usually helps. I set them in the fuel rail first then popped then into the intake and bolt down the rails.
Old Feb 11, 2010 | 05:18 PM
6801's Avatar
vassaline i guess what i really want to know is do i need to reuse the factory c clips that hold the injector on the fuel rail because they dont fit right.
Old Feb 11, 2010 | 05:31 PM
garage_queen's Avatar
you be fine without the clips, at least I haven't run them for 10 years and never had a problem. I don't see how you could ever have any problems since the fuel rails bolt down and hold the injectors in the bores.
Old Feb 12, 2010 | 10:30 AM
DAVE00's Avatar
Use the clips as they will help keep them in position. On the SVO's they work just fine as I have those same injectors on my motor and the clips do clip right on, don't know why you are having issues? As to the bores, do as suggested, rub a little oil on the orings on both sides to help get them to fully seat in the rail and intake.
