9in problems...
What do you have your pinion angle set at? Are the u-joints in good shape?
I had to use 3" U-bolts from a Truck to mount the Sway Bar. I had to cut-down the Straps to go on the stock car Bushings..you can see them in the pic here..
Look into doing it that way, the Sway Bar is good to have.
be careful installing the seals cause they get distorted very easily because you have drive them 6 or so inches into the axle tubes.
As mentioned, I would double check your pinion angle. If it has too much of a negative angle it will stress the rear universal joint. Pull the drive shaft and see if the joint moves in all directions freely.
Mec
