oil pressure sending unit question
Old Feb 18, 2010 | 02:56 PM
iceman15's Avatar
Default oil pressure sending unit question
So Im currently building another motor that is on my engine stand. I plan on transferring some of the small fittings, plugs and sensors from my old one when I swap it out. Can I put on an intake manifold on the motor on the stand before I put the oil pressure sending unit fitting in? Im afraid that if I put the manifold on, that I wont have enough clearance to tighten the fitting on. What you guys think?
Old Feb 18, 2010 | 03:12 PM
RamAir95TA's Avatar
You can get it on just fine. It's actually two fittings that you can put on separately.
Old Feb 18, 2010 | 03:24 PM
iceman15's Avatar
sweet thanks Ramair for the quick response
