Cam only now. Heads or nitrous next?
On the other side, I wouldn't mind just running the motor on spray until it dies so I can do a larger cube rebuild on it.
Questions I have are:
1. Would you recommend le2, AI or Edelbrock heads? (I've had the le2 heads/cam on an old car of mine so I have experience with them).
2. Would you just throw the nitrous on?
3. Would a retune be required with the heads flowing more air?
Mods:
Rebuilt LT1, Stock Bottom End
15K miles on motor
Impala SS Head Gaskets (10.9:1)
Comp Beehive 915 Springs
Port Matched Intake
Ceramic Coated Intake Manifold
Ceramic Coated Jet-Hot Long Tube Headers and ORY
GMMG Chambered Exhaust System
“Ram Air” Intake
1.6 Full Roller Rocker Arms
30lb Fuel Injectors
Motive 4:10's
Auburn posi
Aluminum drive shaft
Performance Oil Pump
Rebuilt Water Pump and Alternator and Powder-coating
Custom Advanced Induction Camshaft 224/234 .563/.577 @ 110 LSA
MSD Opti-Spark
Underdrive pulley
I'm really leaning toward nitrous. What am I going to be able to do with 400 hp that I can't do with 360?...very little. I only go to the track once a year so I don't care too much about track times. (I say 360 because I should be able to get my 1hp out of the ewp i'm putting on lol)
Besides, I'd pay 1,300 for the heads and 550 for a new dyno tune (1,850 total). Nitrous would cost me 650 complete with everything I need.
I don't know why your thinking you don't need a dyno tune for nitrous??? Add $550 to the nitrous and you get $1200.
Nitrous may sound like the cheaper alternative at first but when you fill your 10lb. bottle once a week or every couple weeks at $40-50 a pop it starts to add up very quickly.
I vote to send your stock heads off to Ai to compliment your cam nicely and give you a setup capable of trapping around 120mph. Then save your money and do the nitrous later on.
The 650 is including everything I will need to run it correctly. Plugs, timing (through interface, msd or mallory hyfire) and window switch, warmer and blow down tube. I won't need the window switch with the mallory though since they have them built in.
If you want to educate noobs maybe go to the new member section of the forum.
*edit, maybe you should search on tuning and nitrous. With a wet kit and the correct fueling jets as well as a way to pull timing no dyno tune is required. With a dry kit from HSW, you have the interface that will add fuel and pull timing so no dyno tune needed there either.
Obviously the $650 isn't including the price of a new kit, msd, mallory box or interface controller, etc. etc., I assumed you needed to go out and buy everything in which case it would be alot more than $650 obviously.
Anyways, maybe personal preference but if I'm putting nitrous on the car I want that thing on the dyno to make sure everything checks out well. I actually use to live right by HSW's shop before they moved and learned a thing or two about nitrous from those guys. I was in your boat but I went the heads route instead of spray with plans to spray the car at a later time.
Obviously the $650 isn't including the price of a new kit, msd or mallory box, interface controller, etc. etc., I assumed you needed to go out and buy everything in which case it would be alot more than $650 obviously.
I do actually have a stockpile of nitrous parts already so some stuff I don't need to buy.
