Changing Bulbs to L.E.D.'s need help!
Old Feb 18, 2010 | 06:55 PM
boostedpower's Avatar
Default Changing Bulbs to L.E.D.'s need help!
Hey guys I wanted to switch a few of my lights to L.E.D.'s Starting with the license plate bulbs, reverse bulbs and brake bulbs (all hyper white) from SuperbrightLEDs.com what bulb numbers do i need for my license plate lights? I think the other two are 1156 & 1157 bulbs
Old Feb 18, 2010 | 08:05 PM
bump license plate blubs *bump*
Old Feb 18, 2010 | 08:12 PM
blackodium's Avatar
Search dude search
Old Feb 18, 2010 | 08:39 PM
MTBSully's Avatar
please do not do license plate lights. If you de LEDs there all it does is shine white light on the ground below the plate and it looks like $hit. IMO anyways
Old Feb 18, 2010 | 08:56 PM
I like that bright white look
Old Feb 18, 2010 | 10:25 PM
96silverram's Avatar
It should be a 194 bulb, get a packed 194 LED to get a reasonable amount of dispersion. I run one in mine and it looks perfect at night. Remember on your 1156 & 1157's to check and see if you have bayonet or spade style connections. I think it was late 96 early 97 they went to spade.
Old Feb 18, 2010 | 11:33 PM
daves94formula's Avatar
dont forget that if you do any turn bulb swap you will need a different flasher otherwise it wont operate correctly
