easy and cheap mods???
Old Feb 21, 2010 | 05:18 PM
LigHtEmUp01's Avatar
Default easy and cheap mods???
what kind of mods can i do to get an lt1 to have as much power as an ls1. i want to know the cheaper smaller things. eventually i will do heads and cam.
Old Feb 21, 2010 | 05:30 PM
stburgpete's Avatar
google lt1 free mods it helps a little
Old Feb 21, 2010 | 05:31 PM
LT1's Avatar
LT1
Cold air intake setup, long tube headers, full exhaust, sticky tires like drag radial or slicks.
If your car is auto then highstall converter and rear gears give best results.
Those mod's should get you low 13's.
Old Feb 21, 2010 | 05:57 PM
96lt1m6's Avatar
BUDGET MINDED:
Dragradials
CAI or LID conversion
Longtubes
Nitrous
Old Feb 21, 2010 | 06:03 PM
tarheels24fan's Avatar
i know this is a little off subject but will 97-02 trans am tail light wiring harness work for a 97-02 camaro
Old Feb 21, 2010 | 06:17 PM
96lt1m6's Avatar
different
Old Feb 21, 2010 | 07:03 PM
MasterTomos's Avatar
Full bolt ons including header-back exhaust with cutout(s), Cold air intake, 1.6 Roller Rockers, Underdrive Pully, and a mail order tune from PCmforless.
Also, Drag radial tires, Subframe connectors, an Intake elbow, and a complete tuneup will help.
Then there's weight loss. Dump the spare tire/jack, remove the EGR/AIR pump system(state law/enforcement allowing of course) and a lightweigh battery are a few good things to do to dump off an easy 50ish lbs and still have your car completely street friendly/safe.
Do this list and you'll beat up on many stock LS1's...
