Time for some serious spark plugs!!*!
I think these E3's will go good w/ a tornado or if you really want to go all out throw on an electric supercharger and add some Zmax,!
what plugs would you like compared, E3 vs ??? (I want the E3's so there deff. one)
Now just time to get the motor in the car
The idea behind E3's is that they more completely burn the fuel in the combustion chamber because the diamond head allows the combustion process to spread directly out from the spark to the entire chamber.
The type of metal used has little to do with the power of the spark. Platinum or Iridium coated plugs just have a longer life because those hard metals don't erode as quickly.
Any new spark plugs are going to be better than old spark plugs. E3's probably help with emissions if anything.
A Top Fuel dragster has two spark plugs per cylinder, almost 90 amps of current, and completely erodes the electrodes of its plugs in the first half of a run - for the second half of the 1/4 the engine is just dieseling
.We now return to your regularly scheduled old thread revival.
Yall are all wrong !! I seen the guys on Horsepower TV on spike do a Dyno Test on these plugs and they gained HP and MPG
AND I believe the car ran cooler too
