Lt4 tob
Old Feb 22, 2010 | 03:04 PM
athornt2's Avatar
Default Lt4 tob
I found a guy selling a clutch kit on another forum that I am very interested in buying. The kit includes a clutch disc, an LT4 pressure plate, and an LT4 throw out bearing. I know the LT4 PP is fine as long as its balanced but but will the LT4 TOB work in my 94 LT1 T/A?? Thanks guys.
Old Feb 22, 2010 | 03:32 PM
bigj2717's Avatar
Should be the same thing. All aftermarket clutch kits use the lt4 pressure plate
Old Feb 22, 2010 | 03:39 PM
athornt2's Avatar
Yeah, I knew the LT4 pressure plate was compatible I just didn't know if the throw out bearing was. Anybody have experience with the LT4 throw out bearing in their Fbody?
Old Feb 22, 2010 | 07:38 PM
wrd1972's Avatar
It will work fine. It simply has a thicker pull flange.
Might want to look at this and put some tack welds on the flange:
https://ls1tech.com/forums/lt1-lt4-m...earing-do.html
