Need advice for my new lt1
I have headers big cams cai ported intake and ported heads with arps, aftermarket fuel pump, injectors, tranny, and some other stuff. I'm guessing its at about 400 now with everything done, I'll know for sure in a few days when I have it dynoed.
I want to get as much out of my 97 z28 as I can, and right now the only work I can think of doing to get more hp is forged internals and a supercharger. My concern is how many psi could the lt1 handle from a supercharger with forged internals? What would be a safe amount?
This is a longer term project, buying parts as the money comes, and I have a full hobby shop on base to work with, but no garage of my own, with the exception of friends who are mechanics.
I'm debating on doing the work for the charger but if I'm at about 400 now I have no idea what to expect when I put it in. I really want atleast a 10 second car but refuse to use n2o. My main debate is doing the work to build up this lt1, or converting it to ls1. I'd probably get more out of the ls1 for cheaper, but it would end up costing me more in the long run, having to re do all the wiring, rebuilding everything else, etc..
Point is, with what I have done now, what else can I do to get more power to from this lt1? Like I said, I want atleast a 10 second, I just dont know what else I can do to accomplish this. I'm kinda in a rut. Advice or discussion is appreciated.
What kind of headers do you have?
You have more than one cam?
How big are these "big" cams? When talking about camshafts, "big" is a relative term.
CAI, got that.
Ported intake - who ported it? Are the runners ported or is it just opened up for a larger throttle body?
Ported heads with "arps?" What are "arps?" Who ported the heads? Are they stock castings?
Aftermarket fuel pump. What kind?
What size injectors?
You have a tranny? What kind?
What is the "some other stuff."
Forged internals alone won't give you any horsepower. They support HP made in the valvetrain.
The amount of boost you can run with a forged bottom end could be anywhere from 10 to 30, depending on how much $$$ you put into it.
A hobby shop is far different than a speed shop.
A well-built N/A motor will run 10s for much cheaper than a supercharged forged LT1. Nitrous would be even cheaper.
Answer all those questions, and we'll try this again.
It has hooker longtube headers and it looks like he had them hooked up to a single exhaust pipe that split down the middle to dual.
The cam:GM847 (234@.539/ 242@.558 (1.5RR)----112 LSA)
I have no idea, unfortunately, who ported the heads or intake, nor the castings.
Delteq ignition
walboro 255 fuel pump, 30lb injectors
I'm not the most experienced guy in the world, I'm pretty new to this, so bare with me. I'm still learning. I just figured if I had forged internals, it'd be safer to use with a super charger. I make plenty of money to support it, I just need advice for a good starting point to start working on the 10 second car, and learn at the same time. I don't even know where to begin, so here I am, lol.
CAI, got that.
