ewp leak
Old Feb 25, 2010 | 08:13 PM
TravisMcGill2000's Avatar
Default ewp leak
Just added new ewp to pump and i got a small leak were the ewp bolts to the housing. What would be the best way tp fix it. thanks
Old Feb 25, 2010 | 09:08 PM
stevo9389's Avatar
as aprecautionary measure i put a really thin layer of RTV down before i sealed the pump. has worked great these past 4 years.
Old Feb 25, 2010 | 09:16 PM
fergymoto's Avatar
Same as the guy above when I had one. Did you use any RTV or any type of seal?
Old Feb 26, 2010 | 04:55 PM
RamAir95TA's Avatar
Add the RTV like the above two mentioned. And it goes without saying that both gasket surfaces must be spiffy clean.
