A4 trans cooling lines
Old Feb 25, 2010 | 09:24 PM
jaycenk's Avatar
Default A4 trans cooling lines
Hey all, I messed up when I taged the automatic trans cooler lines as to which one goes where. trans fluid got on the tags and it is not ledgable. Which line goes where in the trans? I can't remember which fitting is the in and which is the out. I have one cooler line with line fitting at the radiator side and another that takes a slip on hose. Thanks
Old Feb 25, 2010 | 09:37 PM
shbox's Avatar
It's easy if you remember that the upper port on the transmission goes to the upper port on the radiator (return line with hose clamp) and the lower port on the transmission goes to the lower port on the radiator (feed line to radiator with crimped on hose).
Old Feb 26, 2010 | 12:28 AM
jaycenk's Avatar
cool thanks so much I will be able to remember that.
