how to pick the rite stall ?
Old Feb 26, 2010 | 06:58 PM
rutt71's Avatar
Default how to pick the rite stall ?
How do you decide what the rite stall 4 your car is I have 94 firebird with lt4 head cam n intake running 8lbs of boost I want tokeep it streetable but yet put down good numbers at the track I have full built tranny and 410 gears any help I was thinkn like 2800 but others are telln me to go bigger like 3600 any help much appreciated
Old Feb 27, 2010 | 12:15 AM
jaycenk's Avatar
These cars have lock up converters so street wise it is fine no matter what you use once you reach lock up. The question is have you had a big stall in an auto on the street before? Go to youtube, I have seen a lot of vids there from guys running 3200, 3600, and even a 4000 showing how the stall is to drive on the street both normal driving and getting on it. Then you pick a stall that helps put you in your power band. If you have a dyno sheet on that engine in the car it will really help pin point what stall.
Old Feb 27, 2010 | 06:30 AM
96lt1m6's Avatar
anything less than 3600 and you will regret it!
Old Feb 27, 2010 | 02:26 PM
SS MPSTR's Avatar
You really need to discuss this with the folks you're buying the stall converter from...
