Delteq and MSD 4 DIS
Old Mar 1, 2010 | 08:58 PM
Formula934's Avatar
Default Delteq and MSD 4 DIS
Hi,
Just bought a used MSD 4 DIS for my Delteq for rev limiting. Question is, how the heck do I set this up? Do I need to purchase anything else to get it to run correctly? Anyone have a good wiring schematic? I havnt been able to find much online. Thanks guys,
-Jeff
Old Mar 2, 2010 | 10:19 AM
DAVE00's Avatar
Originally Posted by Formula934
Hi,
-Jeff
You did get the coil pack interface brakets right? You will need 4 of these and they will mount inbetween the coil and coil base/braket. Needs these to control the spark delivered by the coils.
Old Mar 2, 2010 | 01:05 PM
Formula934's Avatar
No, i havn't. Is that PN 8870? So im confused, I will no longer be using the Ignition control module provided with the delteq, which mounts the coils as of now?
Old Mar 2, 2010 | 01:25 PM
DAVE00's Avatar
From what I understand yes. Do a seach and you'll find some information on the internet. Why are you running the MSD, are you looking for the ability to retard/advance the timing for nitrous or boost?
Old Mar 2, 2010 | 01:32 PM
Formula934's Avatar
Just looking for a rev limiter so I can burn out at the track. I wished it was easier with the delteq to incorporate a rev limiter. I like the way its set up now.
Old Aug 12, 2010 | 11:50 PM
96silverram's Avatar
The Delteq and the MSD DIS4 are the way to go. I have the soft touch set at 6100 rpm's. My two step is set for 5200 rpm's (still working on the relay latch circuit), and the nitrous retard is set for 6 degrees to pull out when the system is armed. I can honestly say that the MSD DIS4 adds a crisper throttle response than the Delteq adds over stock. It also provides you with a tach output if you use a pair of there tach adaptors. All in all it has been a real benefit to my Delteq setup.
