AIR Pump relay for bottle heater
Old Mar 2, 2010 | 07:16 PM
gregrob's Avatar
Default AIR Pump relay for bottle heater
Any tips on this?
So far I've found that the Brown wire on the 10 pin connector on the RH fender is the AIR relay control.
Does that mean I give that 12v from the switch and then use the ground and power from the plug that used to go to the AIR pump?
Whats the 3rd wire in the plug for?
