Intake airflow restriction?
Would comparing the baro KPA(in HG) at the top of datamaster with the Map (HG) at WOT give you accurate data if it does; how much of a drop is normal/acceptable?
Here's a screenshot....
(code was fixed but not cleared...this was the check ride)
The further they are apart the more restriction.
https://ls1tech.com/forums/lt1-lt4-m...-diagnose.html
Shoebox said it best on how to measure.
Went for another test ride, seems like the drop is 1.96" HG so is that bad or good at 6900+?
...here's a shot of engine off.
and engine at WOT
58 MM tb, cut lid with KN filter, stock ducting.
Mike
