Guideplates
Old Mar 9, 2010 | 12:57 AM
gregrob's Avatar
Yes...
Old Mar 9, 2010 | 01:06 AM
BALLSS's Avatar
you will need hardened PR with guide plates
The ISKY adjustables allow for independent allignment to each valve tip.....
I also started with GMPP GP's and they quickly wore, switch to the ISKY
Old Mar 9, 2010 | 08:23 AM
wrd1972's Avatar
The Isky plates are definitely hardened.
If I had to do it again, I would get the Isky's and use the GM plate as the template. I would adjust the Iskys to match the GM in terms of alighnment and throw a tack weld on there to lock them in place. Then bolt them to the head.
Done.
Old Mar 9, 2010 | 11:03 AM
fleetmgr's Avatar
Correct. The plate should be as hard as or harder than the file, as such the file won't cut the plate.
Old Mar 9, 2010 | 11:17 AM
BALLSS's Avatar
Done.
....actually the benefit of the ISKY's is you can adjust them to line up vs the fixed position of a solid GP. I would not "match" them to a fixed GP but instead position them to each valve tip for perfect allignment...something the fixed GP's don't do.
Old Mar 9, 2010 | 11:22 AM
wrd1972's Avatar
I have never known the GM bow tie plates in question to not provide accurate PR alignment. At least I have not noticed anything to be concerned with on mine and hence using the GM GP as the template.
Assuming one did have an issue with the GM GP alignment. I completely agree with you that you now have the adjust-ability to dial it in and account for possible tolerances from head to head. For the perfectionist, this is the only way to go.
