94-95 wiring harness differences
Old Mar 8, 2010 | 04:16 PM
ElkySS's Avatar
Default 94-95 wiring harness differences
are there any i should be aware of? im putting a 95 motor in my 94 trans am. i just dont want any suprises
Old Mar 8, 2010 | 05:36 PM
RamAir95TA's Avatar
The optispark harness will be different when going from a vented to non-vented setup (and vice versa). Other than that they are pretty much the same.
Old Mar 8, 2010 | 06:50 PM
ElkySS's Avatar
i actually just discovered that right before i sat down and read it. thanks tho
Old Mar 8, 2010 | 09:45 PM
shbox's Avatar
If you are using the 95 engine harness in a 94 body, it won't match up without some rewiring. They are definitely not the same. Just use the 94 harness with the 95 engine.
Old Mar 9, 2010 | 12:09 AM
ElkySS's Avatar
^^ i was going to use the 95 harness but it got damaged taking the motor out so im using the 94 harness. i just bought a new opti harness for the vented opti. that should be it right?
