Need help with led instrument panel conversion
Old Mar 9, 2010 | 03:23 PM
vestalsin's Avatar
Default Need help with led instrument panel conversion
I am wanting to change my instrument panel face to a white face, and also change the bulbs to leds. Now I already found the white face plate I want and know which leds to use, I just need some good instructions on how to take out the instrument cluster and to change the face as well as a diagram of some sort to let me know which bulbs are what on the back of the cluster panel... I know how it looks just need to know whats what...I have a 94 Z-28 so I imagine its the same as this 95 one. And as for the white face plate..how do I put it on without messing up the needles? I appreciate all the help, and sorry if I posted this in the wrong section, didnt really know where else to post it...thanks
Old Mar 9, 2010 | 03:24 PM
BLUES MAN's Avatar
The House is Rockin'
pm tootall he's done a ton on pt.net
Old Mar 9, 2010 | 05:18 PM
Tootall's Avatar
I make my own LED bulbs for the clusters . . . I "bust out" the original bulb inside the twist lock and then reuse the twist lock with the new LED.
The over lays allow less light to come in . . . you'll see this later on when it's on.
