worn out clutch forK
Old Mar 10, 2010 | 01:40 PM
draggin97s10's Avatar
Default worn out clutch forK
has anyone worn one out or bent a clutch for i beleive mine is worn out there.
Old Mar 10, 2010 | 02:26 PM
wrd1972's Avatar
Seen them break but never bend. Post 4 pics from all sides.
Old Mar 10, 2010 | 03:38 PM
letsrun97z's Avatar
Mine was worn out fork pads and piviot area
Old Mar 10, 2010 | 07:51 PM
67goatman455's Avatar
mine broke in half at the pivot point just a month ago actually.
Old Mar 11, 2010 | 12:19 AM
the pads were worn they both were sitting at .41 i built them up with some welding and ground them down to .62. see if it works ill let u know
Old Mar 12, 2010 | 10:03 AM
well if anyone cares the trick to adding some metal by building up the fork pads with weld and the grinding them round with the numbers in the above post worked and extremely well and the car shifts like new.
Old Apr 18, 2010 | 01:51 PM
letsrun97z's Avatar
That's the same thing my tranny guy did to get me by untill I got a new one from gm
Old Apr 18, 2010 | 02:32 PM
yea i couldnt justify spending the money when i had a welder and a dremel sitting right next to me. the welds should be alot harder then the cast so it should last. i hope.
Old Apr 18, 2015 | 01:46 AM
darkpanacea's Avatar
Default grinding
Did the worn pads lead to a grinding sound when the clutch was kicked in to the floor all the way?
Old Apr 18, 2015 | 06:24 AM
SS RRR's Avatar
Village Troll
The hell are you all doing to your clutch forks? Mine is factory original and looks as good as new?
Old Apr 18, 2015 | 09:25 AM
superspirit's Avatar
I have seen aftermarket clutches cause this problem, you can grind a 1-16"or .060 off of the T-Bolt to correct the problem. this is what I did and it's been working for 2 years.
Old Apr 18, 2015 | 10:26 AM
SS RRR's Avatar
Village Troll
I bought one maybe two years ago? I just can't remember where. I believe it was from the dealer as well.
Not sure if this is up to date...
http://www.thegearbox.org/catalog/it...17/8252716.htm
