coolant drain procedure?
Put whatever coolant you have now in (green or orange). Just don't mix the two.
If you have pets, make sure to keep them away while you do this, antifreeze will kill them quite dead.
Reseal the plugs with either pipe dope or teflon tape, and put them back in. Put the lower hose back on.
AllData says my '96 has a capacity of 15.1 quarts (just under 4 gallons). Be sure what you put in there is a 50/50 mix with water.
