Stroker LT1
Final config on this setup.
396CI short block built by CNC motorsports.
11.3CR, AFR 210 heads, Accell 30lb injectors
Ported 58mm Intake with PP products 58MM throttle body
Electric water pump and underdrive pulleys
EPP racing headers
Lunatia 60122 cam 231/239 570/586 ligt LSA 110
Trickflow 1.6RR
On another note he has asked me to see if there is any interest in the Procharger setup. Comes complete with everything except fitting for oil pan, Procharger is 7-8pbs boost, all mounts, added fuel pump & regulator, map sensor, belts, and pulleys, coil mount, instructions, etc. He claims to have more than $5000 invested and only about 1500 miles on the setup and would like $3500 or make an offer.
I also used the stock windage tray. just put 1/8" washer between the stud nut & tray. If not using the 3 stock extended studs...Miloden makes them
I have a 383 with 6" rods, SRP pistons
Any 1-peice rear pan will work fine for the engine, ya you have to check stroke and clearances but the issue with LT1 stuff is the k-member and steering rack, they come close if not touching to most pans that are not LTx specific.
The owner is selling the Procharger assembly, look above in previous posts.
