lt1 shortblock and pulleys
if i go eletric water pump do i remove the gear from the block?
by removing ac and power sterring whats the best alt relocating kit?
2nd, yes remove the gear behind the top gear of the timing set and then remove the water pump drive gear and plug the hole in the front cover and water pump.
3rd, it's matter of preference. I like Speed Inc's kit, but it's pricey. It can be duplicated for cheaper if you have some fabrication skills. Do a search as there are plenty of threads that have been put up by many different people....and every one is a little different.
