93 to 94 intake question
http://www.nookandtranny.com/Info_LT1.html
By the way what plugs are you talking about?
93 is SD and uses a chip
94 is MAF and uses a PCM
I suggest running your 383 like its a 94 if your Z is 94. Since all the wiring will be there for a 94 setup, and the 94 PCM is better IMO for tuning.
Is it worth buying a new intake (like the edlebrock) or should I just put the one from my 94 on the 93 motor?
