Still Misfiring!
Engines that miss at high RPM or in a limited range may be fuel starved or have a dirty fuel filter.
The water pump and opti are too close on LT1's and leaks kill rthe opti.
The water near the opti is a bad sign agravated by a proximity design flaw that was later corrected by GM. So, it may need in the near future both a water pump and an opti. In the meantime any plug that did not give a positive snap when it was attached or that is arcing can be fixed cheaply. Fuel filters are about $10.00. I'd try the easy ones first or take to an auto electric shop.
However, I think I found the problem(s). Well the plugs that were arcing, I put brand new ones. Then I changed the boot on the wires that when on those plugs. I also regapped every plug from .035 to .025 and added lots of die electric great on the plugs and the inside of the boots. Lastly, (most likely the cause of all the problems) I have a MSD 6 BTM box to retard the timing because I have a supercharger. Well it comes with a *** that you can turn to retard the timing even more. Well it was all the way to the left(0 degrees retard) so I turned it all the way to the right (I believe it is +4 degrees retard). I did all of that and presto! It fixed the problem
