Alternator VS Valve cover
Old Mar 17, 2010 | 03:28 PM
El Corvino's Avatar
Default Alternator VS Valve cover
Built my 1995 LT1 out of a vette (not sure if it matters for brackets or anything) into a 383. The new valve covers do not allow the alternator to clear by 1/8 of an inch. Instead of being ghetto and denting my valve cover, do any of you know of anything else I can do? Does anyone make an alternator with a smaller case?
This is the new valve covers that are not allow the stock alternator to clear.
This is the part that is hitting.
Old Mar 17, 2010 | 04:04 PM
El Corvino's Avatar
Somebody said I could use an Fbody accessory and that would allow for the clearance. I think just buying an alternator with a smaller case would be easier... What are your thoughts?
Old Mar 17, 2010 | 04:08 PM
AChotrod's Avatar
Speedinc sells a killer alt relocation kit.
Old Mar 17, 2010 | 04:10 PM
El Corvino's Avatar
Where would I be able to pick up the fbody accessory bracket?
I'm sorry - I am not good with the car game. I just enjoy it immensely.
Old Mar 17, 2010 | 04:14 PM
AChotrod's Avatar
You would probably need to find a used one. Even if you use the f-body bracket youll need to grind the alt or notch/dent the VC
This is the speedinc one hides the alt all together and you can run any VC you want
http://ltxtech.com/forums/showthread...elocation-kits
Old Mar 17, 2010 | 04:22 PM
El Corvino's Avatar
I called Speedinc. Their LT1 relocation bracket is $500... bit high in my opinion.
I am trying to figure out which one of the kits on the second link you posted I will need. I am running power steering and AC. The only thing I need to relocate is the alternator... but since they are mounted to the same bracket do I need to buy the one for 500 that relocates both of them?
Old Mar 17, 2010 | 04:30 PM
blk6speed's Avatar
can`t u just notch the alternator,that is what people do when they replace the stock valve covers with after market ones,but that is when the alt. is in stock location...
El Corvino's Avatar
Never mind - I called and they said I had to get the one to relocate everything. What are your guys opinion. The car is done up for show a bit, should I relocate everything to clean up the engine bay or is 475$ a bit much? Am I better off just buying the F-body accessory bracket?
Old Mar 17, 2010 | 04:31 PM
El Corvino's Avatar
notch the alternator... do you mean just grind a tad off the back end? (the part pictured)
Old Mar 17, 2010 | 04:39 PM
BALLSS's Avatar
I read that if you simply unbolt alternator and rotate the case to allow the recessed part of the alt to be where current spot of conflict is and then just put the alt back togeather you are good to go.
cost = $0
...but in your pic you note the most recessed part already hits...
other option is Composite LT4 valve covers which I hear are getting hard to come by.
or just stock VC that have been trimed inside...to clear COMP Pro Mags RR
Old Mar 17, 2010 | 04:42 PM
blk6speed's Avatar
yes but i never done this before...saw it done on here(in pics) try to do a search..but like i said it is on the passenger side..dont know the difference in the spot u will have to grind vs them..good luck.
Old Mar 17, 2010 | 04:44 PM
AChotrod's Avatar
I have the speedinc kit that ditches the AC keeps the ps and relocates the alt. For a show car its a must have. $475 is a good deal IMO
Old Mar 17, 2010 | 04:48 PM
El Corvino's Avatar
The prices for most of these parts are rather high. The relocation kit is looking like what I'll have to buy. Heck, the ugly LT4 composite ones, people are asking 270 for them used... Any other ideas or am I stuck with the relocation bracket. The motor is a 383 in a El Camino...
Old Mar 17, 2010 | 05:12 PM
duh's Avatar
duh
do a search on the alt grinding. I've done it and I have absolutely no issues even on my DD. Takes a little bit of time with a dremel and the alt and you're good. This will solve all your problems
Old Mar 17, 2010 | 05:15 PM
MattSapp95_T/A's Avatar
I have an F Body accessory bracket I would sale you if you need it PM me...
Nice looking engine by the way
Matt
Old Mar 17, 2010 | 06:34 PM
AChotrod's Avatar
Looking good!! The Speedinc kit would set that car off and match the VCs
Old Mar 17, 2010 | 06:53 PM
jaycenk's Avatar
do this to the alt I have an F-body and it needs to be notched. the small bolt you will grind down is one of 4 for the regulator. It dose not need them all.
Old Mar 17, 2010 | 10:07 PM
El Corvino's Avatar
dang guys... Look at my pictures of the car. I guess I will have to grind it. It looks like the relocation bracket will be pushing everything into my power steering and frame since the LT is in a G-body, not an F-body...
Old Mar 17, 2010 | 10:24 PM
blk6speed's Avatar
i personally would try grinding before i spent 400-500 bucks on brackets that may or may not work..
Old Mar 18, 2010 | 02:06 AM
I8ASaleen's Avatar
^ truth. I would never spend that kind of money on something as piddly as a relocation bracket that could be made with some measurements and fab skills.
