Help Please! Engine electrically died on return road after run
I have no instrument panel gauges, or power at the diagnostic port so code reader will not work. it doesn't see a PCM.
There is power at all pcm power feeds in the harness and all grounds in the harness are good. There is also power at the coil leads feeding the LTCC.
We checked all fuses and they are all fine.
Anyone have any ideas where to look next? I'm trying to get this fixed for this weekend we are running in an event and have to leave out Thursday night.
Thanks for any guidance.
http://shbox.com/ignsw/ign_switch_repl.html
I could reinstall the old ignition switch, it still works, and see if I get the gauges to cycle and power to the data link
what bothers me is the smoke and the lack of pcm recognition at the diagnostic port under the dash with the scanner. we have power at the pcm and good grounds. just nothing after the pcm. headlights all work, aftermarket gauges work just the factory dash gauges that receive a signal from the pcm have nothing.
what has me confused is there is power to the pcm at all the pin outs that should show power and all grounds show connected.
We will be also rechecking the fuse box and power pin at the DLC tonight if power is present I hate to say it but it sounds like a pcm went bad.
thanks to everyone who had input in this to help brainstorm this problem I really appreciate all the help!
We had to find it since this weekend we are running in the s10 supernationals in Florida Emerald Coast Supercooler dragway. Now we are ready to go!
http://www.youtube.com/watch?v=7ak_t...layer_embedded
we will be at the Emerald Coast Supercooler dragway near Milton Fl. (Holt)
