Lt 1 IAC Removal
Old Mar 22, 2010 | 02:09 PM
redface8's Avatar
Exclamation Lt 1 IAC Removal
Hey gotta quick question on removing the IAC, i stay in the dorm rooms so i really cant remove the throttle body and go through the process of draining the coolant out. So I'm wondering if I can remove the IAC without removing the TB. I know it'll be a headache but I don't have a choice and I really want to know if this is possible.
95 Camaro LT1
Thanks!
Old Mar 22, 2010 | 02:25 PM
the_merv's Avatar
Veteran: Air Force
Do a TB Bypass real quick, then unbolt the TB. Clean up the little coolant that will seep out.
Old Mar 22, 2010 | 02:30 PM
redface8's Avatar
Whats a Throttle Body bypass?
Old Mar 22, 2010 | 02:42 PM
the_merv's Avatar
Veteran: Air Force
Good ole Rob's website will help ya..
Basically run that Hose coming from the Radiator to the Metal Line on the passengers side of the Intake. Make it NOT go through the Throttle Body.
Old Mar 22, 2010 | 03:00 PM
redface8's Avatar
Cool! Thanks guy, appreciate the help!
