Opti Vent?
Old Mar 24, 2010 | 03:41 PM
FlamingChicken's Avatar
Default Opti Vent?
I have decided to swap back to stock ignition and need the vent/vacuum harness for the opti but its like 80 bucks from the dealer! Can you just use vacuum hose from the elbow to the distributor and then a vacuum hose with a check valve from the distributor to the intake? i dont see why not but figured i would ask first.
Old Mar 24, 2010 | 03:43 PM
BadBlackZee's Avatar
I have bo reason to disagree with you...there is so little vacuum on that line its negligible anyway
