Best Fuel Pump To Buy???
Old Mar 25, 2010 | 11:19 PM
Stroked97TA's Avatar
Default Best Fuel Pump To Buy???
I know that there are more than a few fuel pumps that are made by aftermarket manufacturers, and working at a Chevrolet dealership I am a firm believer in OEM parts as in most cases you get what you paid for. My problem is that I simply cannot afford even my discounted price on a fuel pump from GM. So my question is which pumps have worked the best for those of you who have done a replacement swap? Granetelli, Walbro, Aeromotive, Holley, etc... Please give me some advice and/or pro's and con's about a swap that you might have done so that I can make the best informed decision. I REALLY appreciate the help guys, thanks a lot.
Old Mar 25, 2010 | 11:50 PM
the_merv's Avatar
Veteran: Air Force
I have a Walbro 255 and it's working well for me.
Old Mar 26, 2010 | 01:50 PM
koolaid_kid's Avatar
The Granatelli is a Walbro, I purchased one. Had the name, part number and everything right on it. I have heard the Holley is also a Walbro.
Whatever you buy, make sure you get the install kit for it, lines, clamps and sock. And don't buy those cheap Chinese knock-offs from fleabay. Total crap.
Old Mar 26, 2010 | 03:40 PM
SoxXpupPeT's Avatar
same here. walboro 255 FTW!
Old Mar 26, 2010 | 09:47 PM
~BuMps AloT~'s Avatar
Walrbro 255 here. Works excellent
Old Mar 26, 2010 | 09:59 PM
airfix's Avatar
Where's the best place to buy a walbro 255 pump kit?
Old Mar 26, 2010 | 10:44 PM
BigBadWhitey's Avatar
Racetronix makes a pretty sweet set, is BC british columbia? Their canadian as well.
Old Mar 27, 2010 | 12:09 AM
stevo9389's Avatar
i have the walbro gss340. supposed to be a high pressure version of the 255 and it doesnt fit as perfectly in the bucket as the regular 255's. test your wiring and voltage @ the pump before you install or else you will prolly end up replacing it in a few months.
Old Mar 27, 2010 | 01:07 AM
myltwon's Avatar
granatelli, walbro, racetronix, all the same just come with different kits to install it
Old Mar 27, 2010 | 08:47 AM
SoxXpupPeT's Avatar
when you get the 255 dont forget to get the hotwire kit aswell
Old Mar 27, 2010 | 08:58 AM
camar0corey's Avatar
If you can swing it might as well get the Racetronix setup, the wire kit is completely worth it.
Old Mar 27, 2010 | 10:54 AM
dochidalgo's Avatar
Wise advice though...ditto that
The Racetronix fuel injectors are way better than stocks and other brands
dochidalgo
