11's Cam Only Finally
60'--1.67<-also a new pb best
330--4.933
1/8--7.65@91.46
1000--9.99
1/4--11.96@115.79
launched around 5500 rpm and my shift light is set at 6200rpm.
Cam-230/236 .544 .555 lift 112lsa
EWP, Moser 12bolt with 4.11's, Jet Hot LT's ORY w/cut out, K&N intake, march underdrive pulley, comp 1.6 rr's QA1 R's up front, Comp Eng. rear shocks, adj TQ arm, sfc's, lca's, rear sway bar. I also run on bogart D-10's w/ 26x10.5 ET Streets ..I only have removed the ac, front sway bar, and spare tire and jack. The whole interior is in the car it weighs about 3500 w/ driver.
How many miles on the car?
That said go look into the weather you ran in. That was a meaningful part of the equation. Not trying to discourage, just trying to say that as the weather warms and the BARO drops you may not repeat or better this till fall when the air gets good again.
I've got 73k miles on the car.
96capricemgr-I know what your saying about the weather. I wont even try for new bests soon just b/c of the heat and humidity in the MD area.
good DA or not! Congrats, that is an awesome accomplishment! I was at Beaver Springs up here in PA yesterday with friends and we had some negative DA it was great.
You missed out on some good "blowing **** up" the other day with Ian. I brought the Garand and M1917 out and he got a stiffy shooting them. Hopefully we can all hook up and blow some more produce up once I get a weekend free.
