Car is running rough
Old Mar 28, 2010 | 05:06 PM
Drew24's Avatar
Default Car is running rough
So my car is running rough idk what it could be i changed the opti, Plugs, Plugwires, O2 sensors, cleaned my mass air flow sensor, Cleaned and reoiled the CAI, and seafomed the car. Oil pressure is good and not smoking but running really rough at idle. Anyone think they know what it could be?
Old Mar 28, 2010 | 05:13 PM
bigj2717's Avatar
Maybe your fuel filter or fuel pump. I would go for the filter first
Old Mar 28, 2010 | 05:19 PM
Drew24's Avatar
I replaced the fuel filter and the pump was recently changed about a year ago. Im completely stumped
Old Mar 28, 2010 | 05:46 PM
jaycenk's Avatar
Check the fuse for the engine sensors and make sure it is good.
Old Mar 28, 2010 | 05:50 PM
Drew24's Avatar
Ok checked the relays and checked for blown fuses and checked all the plug wires to make sure they are in there tight and they are no check engine light or anything.
Old Mar 28, 2010 | 05:52 PM
bigj2717's Avatar
Have you tried looking at the opti harness or checking for vaccum leaks?
Old Mar 29, 2010 | 01:56 PM
Drew24's Avatar
Yeah i changed the opti harness and made sure the vacuum lines are all pluged in. I also just changed the coil and same thing
