94 PCM on a 93 Z28
"Feed from fuel pump and fuel pump relay to prime connector" (Gray wire)
Take 93 body harness side C220 (F) and connect to 94 engine harness side C210 (D)
"Serial Data Signal" (Tan wire)
Connect wire straight from Cavity "M" on DLC port (diagnostic port) to 94 engine harness side C220 (F)
Use these as references:
http://shbox.com/1/harness.htm
and
http://shbox.com/1/harness_connector_faces.htm
