Timing chain choices
Old Mar 30, 2010 | 10:08 AM
BCook839's Avatar
Default Timing chain choices
I'm trying to find a good timing chain for my cam swap. I'm either going with LT4 hot cam or a CC503 at the biggest.
I notice theres a broad spectrum on summit. Either 100 bucks or 300 bucks. I have no experience with running anything but what came in the car. Any suggestoins on how much to spend/what level to get?
The GM set is tempting.
Here is a link to summit's selection for the LT1:
http://www.summitracing.com/search/m...?Ns=Rank%7cAsc
Thanks
Old Mar 30, 2010 | 11:42 AM
enjoi355's Avatar
i would suggest replacing only the chain if the teeth on the crank/cam sprockets arent damaged
idk the part number though
Old Mar 30, 2010 | 12:27 PM
StealthFormula's Avatar
If the factory sprockets appear to be in good shape just go ahead and buy a stock replacement GM chain for ~$50 and you will be good to go.
Old Mar 30, 2010 | 12:29 PM
ls1adamls1's Avatar
werd thats all i did. and my stock chain was not even that loose.
Old Mar 30, 2010 | 12:33 PM
BCook839's Avatar
Cool beans. The car has 75,000 miles on it so it can't be too bad. Thanks for the tip guys.
