code 16...please help
Old Mar 31, 2010 | 09:01 AM
scott937's Avatar
Default code 16...please help
My car threw code 16-low res pulse circuit failure. I've put in a new map sensor,opti spark,distributor and nothing has worked. Any other suggestions would b appreciated...I heard to check the map wiring but not to sure how to. Thanks
Old Mar 31, 2010 | 11:11 AM
RamAir95TA's Avatar
Check the harness connector for the optispark and make sure it isn't corroded, loose, or broken.
