Wiring a Moroso switch panel
Old Mar 31, 2010 | 06:42 PM
Bad_tx_Z28's Avatar
Default Wiring a Moroso switch panel
Hey guys, im getting ready to install a Moroso 6 switch panel in my camaro. Its pretty much going to be a stip car so im trying to keep things simple. The switch panel will be used to start the car and turn on/off the following functions. Ignition, fans1 &2, fuel pump, and nitrous arm. My only concern is for the starting and ignition portion of the wiring. If anyone could point me in the right direction it would help greatly. Thanks!
Old Mar 31, 2010 | 06:57 PM
jaycenk's Avatar
What do you want to know about it?
Old Mar 31, 2010 | 07:24 PM
Bad_tx_Z28's Avatar
Mainly what needs to be wired to the momentary swith for it to turn the starter.
Old Apr 2, 2010 | 01:18 AM
jaycenk's Avatar
you need one switch for ignition power, and a momentary push button or momentary rocker switch for the starter to engage.
Are you asking what wires to hook up? I don't have a diagram for 94
Old Jan 19, 2019 | 10:00 PM
JCS94's Avatar
Hey guys, I’m wiring in one of these for a third gen with an ls and have an issue... do any of you know what wires to connect on either sides of the ignition switch on the switch panel so I can flip the switch and have all ignition power for the gauges and the fuse/relay block (pretty much the whole car) to work based off of that one switch? I know that two red wires go into the ignition switch and a pink wire comes off of the ignition switch but that can’t be the only ignition output for the whole car. Wondering if anyone knew from a fourth gen that I could “translate” to a third gen
Old Jan 21, 2019 | 09:36 AM
shbox's Avatar
You'd need a wiring diagram for a 3rd gen to know what goes where.
Old Jan 21, 2019 | 10:38 AM
SS RRR's Avatar
Village Troll
For a remote starter it should be easy enough to connect one wire off the starter solenoid to a continuous 12v positive source. Either off the starter or battery. However that would stilll require some way to turn on the PCM/FP and ign. You may be able to get that info from a Haynes manual if you can find one for a 3rd gen.
