MSD 6AL Mounting
First, cooling is the main problem. Fix that, and you can mount it on the Equator. A fan, such as a PC fan, should fix that easily. Glove box, console, who cares. It is cooling, and only cooling, that is an issue.
Second, proximity to the coil is paramount. I plan to mount mine on the front, driver's side, in front of the radiator. Those who think the engine compartment is cool are being unrealistic, IMHO.
The only concerns are:
Cooling - does your location offer sufficient cooling?
Proximity to the coil and Opti - don't allow a voltage drop over the length of the wires. Correctly adjusting wire gauges will rectify this issue.
Mount it on the moon, but make adjustments accordingly.
The MSD instructions are based on the fact that some do not consider cooling an issue. It is. Cool it correctly, and it can be mounted anywhere.
