Help please ODD problem, car dying....
Old Apr 6, 2010 | 08:11 PM
LALT1's Avatar
Default Help please ODD problem, car dying....
Ok guys this the 6th LT1 car I have had and never ran across anything like this on mine or any customer cars.
My car will run fine if the outside temperature is below 60 degrees, it will run fine for about 20 minutes then it will throw the P0300 code and die. It can set for about two minutes refire and run fine for about 45 seconds then die again. It's just as if it has ran smack out of gas but it is getting plenty of fuel, losing all fire it would appear. It will run fine on my way to work 60 miles of the morning, on the way home in the afternoon is the only time it acts up and has been consistent. It has a new coil, just replaced it. I have also tried running it in open loop which made no difference. Open to any and all suggestions.
Car is a 97 Z M6 car, headers and bolt on stuff only.
Thanks in advance.
Old Apr 6, 2010 | 08:51 PM
stilltime's Avatar
Not 100% positive, but it sounds like the same symptoms mine had when my ICM went out. Lucky for me, that was the last part I bought after replacing the opti, water pump, plugs, wires, opti harness, coil, and coil wire. The ICM got it running on perfect, but if you get one, get a GM one.
Best of luck,
Chris
Old Apr 6, 2010 | 09:09 PM
LALT1's Avatar
well I have wondered that, mine tested out fine, but again it will run fine for a good while.
Thanks
any other thoughts appreciated.
Old Apr 6, 2010 | 09:41 PM
stilltime's Avatar
When did you test it, after it had been driven for a while or after the car had been sitting. It collects a lot of heat bolted to the head, and that's when they go out, only after being hot for even a short period of time.
Mine had been acting up for about a week and one morning I got in my car to go to work, 1/4 mile down the road the car completely shut off, that's the amount of heat it took to give my ICM one last breath at least.
Parts stores' "load testing" on the ICM isn't as accurate as your car's electronics, the local stores didn't even know what an ICM was, OR how to test one...
Old Apr 7, 2010 | 03:50 AM
LALT1's Avatar
It was by no means hot as I had taken it off and ran it over there, you might very well be right.
