Which temp sensor?
Old Apr 15, 2010 | 01:37 PM
LadyDriven's Avatar
Default Which temp sensor?
I'm trying to order a coolant temp sensor online, but it gives me 2 different ACDelco part #s. How do I tell which I need?
Old Apr 15, 2010 | 02:00 PM
RamAir95TA's Avatar
There are two different coolant temp sensors - a one-wire sensor for the driver side cylinder head (that drives the dashboard gauge) and a two-wire sensor for the water pump (for the PCM).
Old Apr 15, 2010 | 02:01 PM
boosted LT1's Avatar
One is for the guage one is for the computer. I bought mine at O Reilly's can't remember how much but look at the connector before you go that way you will know when they hand you the correct one. As I remember it is universal from 1986 or 1987 - 1997. Also it already had 'sealent' on the threads so a drop right in and go solution.
Good luck
Old Apr 15, 2010 | 02:10 PM
LadyDriven's Avatar
Oh, so I need both! lol. Thanks. I feel like an idiot
Old Apr 15, 2010 | 02:25 PM
1badzee's Avatar
Old Apr 15, 2010 | 02:34 PM
shbox's Avatar
1993-1997 coolant temperature sensor for gauge AC-Delco # 213-77 GM # 25037332
1993-1997 coolant temperature sensor for pcm AC-Delco # 213-310 GM # 15326386
Old Apr 15, 2010 | 02:37 PM
LadyDriven's Avatar
^ Thanks!
Its telling me its 213-77 & 213-928 though ???
Old Apr 15, 2010 | 02:38 PM
LadyDriven's Avatar
I punched in 213-310 and it came up as being superceded
Old Apr 15, 2010 | 03:45 PM
shbox's Avatar
Before posting, I verified the AC-Delco numbers at the AC-Delco website.
213-310 still shows as correct and 213-928 shows for the applications below (not f-body):
BUICK(3)1993-1995
CHEVROLET(4)1993-1995
BERETTA GTZ(1)1993-1993
BERETTA Z26(1)1994-1994
CAVALIER(2)1995-1995
OLDSMOBILE(7)1993-1995
PONTIAC(9)1993-1995
GRAND AM(7)1993-1995
SUNFIRE(2)1995-1995
Old Apr 15, 2010 | 03:49 PM
LadyDriven's Avatar
Weird. The site I'm using might be screwed. Or sometimes, ACDelco Canada differs slightly from the US. Its a pain in the ***.
LadyDriven's Avatar
And THANKS!
