good oil pan with baffle
Old Apr 16, 2010 | 07:12 AM
duckvader's Avatar
Default good oil pan with baffle
built a 383 and used arp main studs. need a oil pan with baffle. what are some good ones.
Old Apr 16, 2010 | 09:21 AM
RamAir95TA's Avatar
Canton 242T here.
Old Apr 16, 2010 | 09:38 AM
Nastyc4's Avatar
I used a canton on my last 388 lt4 buildup. horrible pan it leaked everywhere but still did the job. for the price it can't be beat. Using a Jeff Johnson Billet Fab pan for my new 8000 lt4 buildup but needed a custom pan to fit the custom Titan Gerotor billet oil pump. It's a $200 vs $750 comparison though.
Old Apr 16, 2010 | 10:12 AM
suicidal racing's Avatar
get the moroso 7qt pan street strip..it will be on summit but wont come up when searching for a lt1..it will be the one that has a pass side dip stick..the canton one listed for lt1s is not a street strip style pan it is a road n track pan an is only 5qts if i remember right...i also say get a full crank scrapper,full windage tray and then a summit pick up will work fine when you get the pan..it will be like 250 for it all with shipping..
Old Apr 16, 2010 | 01:38 PM
slingshot928's Avatar
I have the canton 242T, 8k hard road mileage and the only leak has been from the drain plug, which I am fixing when it comes out of storage. You have to make sure you have the right gasket, and a one piece gasket from felpro is the best.
Old Apr 16, 2010 | 03:14 PM
JB_97ws6TA's Avatar
You can't blame oil leaks on the pan! If you didn't make sure that the rails were flat or put rtv on the corners that is your bad. I also am using the 242t and it sealed up tight as a drum, is baffled, has a good windage tray but their "crank scraper" leaves much to be desired. That scraper is a POS plus you have to beat the hell out of it for the stock dipstick to clear but other than that the pan is great
Old Apr 16, 2010 | 05:37 PM
duckvader's Avatar
do you have the parts numbers from summitt for all the parts. the moroso i thought came with all the parts you mentioned. want something to fit 97 formula with pacesetter headers
Old Apr 16, 2010 | 06:33 PM
at home i do..but im out of state now on vaction..the street strip pans dont come with full windage trays or scrapers...the race pans do an there like 350-400..when you find the pan..just go into other recomended parts an the tray should come up..then just run crank scraper in a search an grab the sbc one.....do a search for oil dip stick for just this section an there was a guy about a week or so ago asking about it an says the part number in it..
Old Apr 16, 2010 | 08:39 PM
jaycenk's Avatar
With a moroso you have to use an oil pump witha 5/8ths pickup port and you have to use moroso's pick up, they make 2 and they only fit a couple of pumps. Look on thier web site for the info. Then you have to set up the moroso pick up to the right hight. If you run LPP long tubes the oil level sensor has to be pluged due to the fact they lay on the sensor.
Old Apr 16, 2010 | 08:47 PM
FASHOOTER's Avatar
Milodon 30909 Comes with full length windage tray. I am happy with mine fit great and no leaks!
Old Apr 16, 2010 | 09:10 PM
ElkySS's Avatar
anyone know of a high capacity pan that uses the stock pick up? mine is welded on. maybe one with kickouts?
Old Apr 16, 2010 | 09:38 PM
ive used plenty of moroso sbc pans with out there pick ups or pumps.
Old Apr 16, 2010 | 10:23 PM
WS Sick's Avatar
I used the Moroso pan and the moroso pick-up on a mellings pump.
Old Apr 16, 2010 | 11:02 PM
Nastyc4's Avatar
I sure Can. It didnt leak at the gasket. it leaked in about 4 places all from the welds. Very very **** poor quality. the rails were flattened etc no leaks from the gasket. Even used a custom clamp style clip bolted to the side of the block to make sure it didnt leak at the dipstick.
Old Apr 17, 2010 | 09:15 AM
Puck's Avatar
Did you buy it used? It may have been used as a jacking point or something.
I'm sure it could have been a manufacturing error in your case, but the welds on my canton pan are some amazing quality welds, just like my canton VCs.
Can't beat them for the price IMO.
