Need picture/location of C200 plug, PLEASE!!
Old Apr 16, 2010 | 02:46 PM
1badzee's Avatar
Default Need picture/location of C200 plug, PLEASE!!
Having this wiring issue at the moment and I really need to find where bulkhead connector C200 is/looks like. Please someone point me in the right direction.. Thanks in advance.
Old Apr 16, 2010 | 05:26 PM
FASTFATBOY's Avatar
There are 4 C200's....a,b,c,d.
C,D are in the left kickpanel/steering column area.
What does it go to?
EDIT A,B,C,D look like they all go to one bulkhead. It says" Between LH kick panel and steering column.
Its the forward lamp harness/crosscar harness it says in the manual. C200D which is the female end has 48 wires, has a bolt through the center.
Old Apr 17, 2010 | 10:57 AM
garage_queen's Avatar
Pull all the panels off from below the steering wheel. Looking up from below, it will be over towards the door just behind where the flashers are. You should see all the wires leading into the connector, with a bolt going through the middle. It's MUCH easier if the seat wasn't in the car and your could lay on your back and look up. Not sure it helps much but here's a pic.
Old Apr 17, 2010 | 11:20 AM
1badzee's Avatar
Figured it out, thanks guys!
