Intake Bolt Torque Specs???
Old Apr 19, 2010 | 10:29 PM
97ramsst's Avatar
Default Intake Bolt Torque Specs???
Can someone please give me the correct torque specs for LT1 intake bolts? I found 71lbs somewhere online but I dont think thats right being I broke the 3rd one I went to tighten off in the head!!!
Old Apr 19, 2010 | 10:36 PM
robsquikz28's Avatar
2 stages tq in
1st 18 ft lbs
2nd 35 ft lbs
Old Apr 19, 2010 | 11:24 PM
97ramsst's Avatar
Originally Posted by robsquikz28
2 stages tq in
1st 18 ft lbs
2nd 35 ft lbs
Thanks, that makes much more sense than 71!!!
Old Apr 19, 2010 | 11:31 PM
RamAir95TA's Avatar
71 ft/lbs. sounds more like head bolts to me.
Old Apr 19, 2010 | 11:48 PM
airfix's Avatar
For future reference, here's all the torque spec's you should ever need.
http://www.bfranker.badz28.com/fbody/torquespecs.htm
Old Apr 19, 2010 | 11:50 PM
97ramsst's Avatar
Yeah I knew it was A LOT but I checked 3 times and thats what it said. I should have used common sense and knew that was too much.
I got the broken bolt out easy thank the Lord....now i just need to find one or a set to replace it! Any suggestions???
Old Apr 20, 2010 | 07:13 AM
shbox's Avatar
It's 71 INCH pounds for the first pass. Whatever you saw was mistyped or misread.
Old Apr 20, 2010 | 11:29 AM
am_muscl's Avatar
^^ does it really matter the sequence in which the bolts are tightened? I just put my intake on last weekend and I just started tightening all of them, obviously I checked and rechecked to make sure everything was tight but I didn't think that it would be a huge deal on the sequence.
Should I re-do it?
Old Apr 20, 2010 | 11:32 AM
fleetmgr's Avatar
Yes, it can matter alot. Were it me, I'd loosen it all up and start over. The sequence does a couple of things. It keeps you from cracking the intake from stress due to torqueing the manifold with a front to rear twist. It also ensures that the gaskets seal properly.
Old Apr 20, 2010 | 11:35 AM
RamAir95TA's Avatar
If you just tightened them any which way, I'd completely remove the manifold and start over with new gaskets and RTV, but that's me.
Old Apr 21, 2010 | 01:08 AM
jaycenk's Avatar
If you look real close to that 71 number online you will notice that it is 71 INCH lbs and not FTLBS. lol made that mistake already.
