Single plane guys
Old Apr 21, 2010 | 08:49 AM
86formula's Avatar
Default Single plane guys
what are you using to plug the distributor hole? anything thats not custom made?
Old Apr 21, 2010 | 09:24 AM
quik95lt1's Avatar
I just whipped up a plug outta aluminum on the lathe and then just used a aluminum strap and a dizzy stud to hold it in. If you dont find anything else I can prob make another one for you if you want?
Old Apr 21, 2010 | 09:31 AM
STOCKTA's Avatar
I would have quick95lt1 make one for you as I always admired his car and work put into it. I could not rig anything up on the two victor's I have here that would look or work as good as what he fabbed. Im running a carb and distributor anyways or I would have him make me one also. Love that car quick95Lt1!!!!!! big inspiration for me to want to run a solid roller after seeing your results and vid's
Old Apr 21, 2010 | 09:44 AM
Formula383's Avatar
I have something similar on mine. Just an aluminum plug pressed in and sealed with RTV. Nothing immediate comes to mind that's not custom.
Attached Thumbnails Single plane guys-project-formula383-20100317-00002.jpg   Single plane guys-project-formula383-20100317-00003.jpg
Old Apr 21, 2010 | 11:03 AM
Puck's Avatar
I plan on runny a dummy dist to ditch the plastic POS oil pump drive gear.
I don't trust the plastic hold down on it, and have seen more then one occasion of it cracking from the upward force.
Old Apr 21, 2010 | 03:56 PM
86formula's Avatar
thanks guys, quik95lt1 you have a PM
Old Apr 21, 2010 | 05:49 PM
Tensec94z's Avatar
Default plug
I just knocked a freeze plug into mine.
Old Apr 21, 2010 | 06:52 PM
T/A KID's Avatar
I had all of that stuff welded and shaved, I have about 100 aluminum circles that fit that hole perfect, just need to have it tig welded.
Old Apr 21, 2010 | 09:59 PM
FASTFATBOY's Avatar
I run a MSD Part# 8513 in my dist hole to run the oil pump drive. I have an extra brand new one for sale.
Old Apr 22, 2010 | 01:36 AM
Speed Density's Avatar
hashtagBMW
I just have a plug with a dizzy holder on my old setup.
