part number for bearings
Old Apr 22, 2010 | 04:57 PM
redtransam95's Avatar
Default part number for bearings
need the part number for clevite 77 rod and main bearings for lt1 std size on both performance seris and high performance seris numbers on both since im not sure witch i want to go with yet
Old Apr 22, 2010 | 05:00 PM
also whats the cutoff point before you need to stud your mains 2 bolt that is
Old Apr 22, 2010 | 07:32 PM
no one knows?
Old Apr 23, 2010 | 11:24 PM
wow no one knows bump
Old Apr 24, 2010 | 10:02 PM
bump come on
Old Apr 25, 2010 | 12:33 PM
SpeedDensityZ's Avatar
I did some looking for you
Rod Bearings- http://www.jegs.com/i/Clevite/695/CB663P/10002/-1
Main Bearings- http://www.jegs.com/i/Clevite/695/MS909P/10002/-1
I was curious myself since I've been looking for the same parts.
Old Apr 26, 2010 | 12:54 AM
gregrob's Avatar
I would use the H bearing from Clevite
Old Apr 26, 2010 | 02:33 AM
JB_97ws6TA's Avatar
I went with non coated clevite h series main and rod bearings and coated cam bearings, that is what my machinist recommended
Old Apr 26, 2010 | 05:56 PM
whats the part numbers for h series std size?
Old Apr 26, 2010 | 06:00 PM
gregrob's Avatar
http://lmgtfy.com/?q=summitracing.co...ite+h+bearings
It was only the 5th result down
Old Apr 26, 2010 | 11:15 PM
speedracer2536's Avatar
what is wrong with the 77 series bearing
Old May 18, 2010 | 06:55 PM
what would you sugest for a motor using stock crank spinning to 6800 rpm? p or h
Old May 18, 2010 | 06:58 PM
RamAir95TA's Avatar
I used and recommend Clevite H-series. Just let your builder order the correct bearings, IMO.
