AFR LT1 heads Question
Old Apr 25, 2010 | 10:42 AM
Puck's Avatar
Originally Posted by 96capricemgr
People don't quite comprehend there is a difference between being fastest at bench racing and being fastest on track.
Why on earth would you choose a company to work with then ask them to work with a product they would rather not??? Going to pay a professional for advise just to ignore it?
Exactly...and I don't see a reason to spend all that money on a new set of heads and porting to go with a name when he already has a great set of heads on the car .
If he was working with just a shortblock I would say the AI TFS kit would be the way to go for his money, but it wouldn't make any sense now that he has a set to work on.
Old Apr 25, 2010 | 01:02 PM
ElkySS's Avatar
well the thing is, the car is my daily driver. its my only car. what i was originally planning to do was save up for the tfs and turn around and sell the afrs for minimum down time. but im starting to consider porting the afrs. i just havent figured out how to deal with the down time
ElkySS's Avatar
especially since the afrs are worth so much
Old Apr 25, 2010 | 01:10 PM
thehammer69's Avatar
Have you considered having Tony Mamo from AFR do the porting?
Old Apr 25, 2010 | 01:21 PM
96capricemgr's Avatar
What Puck is trying to say is blindly defend your mistake to the bitter end like so many others.
Old Apr 25, 2010 | 02:28 PM
ElkySS's Avatar
i guess ill just make that decision when it comes time to. its going to be a while before im ready
Old Apr 25, 2010 | 02:50 PM
Puck's Avatar
Not sure I'm following you, thanks I think???
I was pointing out that it would not be a good way to spend money to sell the AFRs, to then spend MORE on new castings and then have THOSE ported.
Not wanting down time is understandable, though .
Old Apr 25, 2010 | 04:41 PM
Wicked94Z's Avatar
i wasnt aware that afr 195s were a bad head??
Old Apr 25, 2010 | 05:55 PM
illusions's Avatar
they are if your an AI
You know some have to defend their poor choices.
Old Apr 25, 2010 | 06:30 PM
Matts94Z28's Avatar
Nope... some stock casting AI heads in a caprice would walk anything with AFR's, simply because it's the proper set up. God forbid anyone ever put AFRs on a cc306 cam'd motor!
Old Apr 25, 2010 | 07:52 PM
jabawalkie's Avatar
Isn't comparing AI to AFR like comparing apples and oranges? One makes a casting and the other just ports them.
The real comparison is if the op sends his AFRs to Tony and somebody else sends the same casting the op has to AI. Or for lesser value send the AFRs to Tony and compare what AI can do with the TFS's or Darts.
Old Apr 25, 2010 | 10:03 PM
  #32
Wicked94Z's Avatar
no Ai does strictly cnc port work. if they don't want to do hand porting in house, who does their ports for their programs?
Old Apr 26, 2010 | 01:54 AM
  #33
31camaro's Avatar
so what you guys are saying is that the AI 200cc heads are equal to the afr 195's ot 180's?
Old Apr 26, 2010 | 02:15 AM
  #34
define "equal" as you use it here...
Old Apr 26, 2010 | 09:27 AM
  #35
31camaro's Avatar
flow numbers, hp/tq numbers from head to head
Old Apr 26, 2010 | 09:56 AM
  #36
In that case, I'm sure they are "equal" enough. Except I have a hunch that even though peak HP numbers should be similar, the AFR's would produce a superior torque curve. This is assuming of course that the user spec'd his build correctly.
Old Apr 26, 2010 | 10:22 AM
  #37
ElkySS's Avatar
what im wondering is if a ported 195 will be enough to properly supply a 396. if there is something better for what i want to do, let me know, i was thinking afr 227 but that looks a little more complicated than i was looking for
Old Apr 26, 2010 | 10:28 AM
  #38
31camaro's Avatar
i would say yes, because from what i have read in the provided link they are a damn good performing head out of the box, and ported i bet they are even better
Old Apr 26, 2010 | 10:46 AM
  #39
Puck's Avatar
Short answer: Yes.
Old Apr 26, 2010 | 11:33 AM
  #40
ElkySS's Avatar
long answer?
