95 M6 PCM in 97 M6 car??
Things needed:
obd 1 pcm
obd 1 knock sensors
Is that all?
I've been running my 97 M6 SS off a 95 pcm from a M6 Trans Am. My car is a 3 channel ABS...it was a 4 channel, but that didn't make any difference. The only problem I had was that my rear gears were already swapped to 4.10 and I'd deleted EGR. A friend took care of that in the obd1 pcm with tunercat.
There are zero wiring mods to make. Just disconnect the battery, swap the knock sensor, swap the pcm, reconnect the battery and you're done. I didn't even think to disconnect the battery and had no problems, but I'd advise against leaving it powered.
But seriously i agree with you partly that for your everyday drive around program to be on the conservative side , if the KS is tuned out, but I allways go agggresive when I know the quality of fuel.
For instance (I have tunercats and a wideband) when I drive to work or around town on 91 I do like you suggested and though the curve itself is somewhat aggressive the total timing would be about 4 or so down. When I am at the track I have a different program I load since I am running 100 plus unl.
In addition, if you don't want to take the time and tune your stuff for differnt situations you shoudnt be jacking with stuff...lol
http://www.eficonnection.com/eficonnection/default.aspx
