nitrous or not??
Old Apr 25, 2010 | 12:37 PM
ale76051's Avatar
Default nitrous or not??
ive got a 96 bird with 153000 miles. it runs great doesnt burn oil or leak anything, so i was wondering if it would be safe to put a little 75 or 100 shot on it? thanks for any advice
Old Apr 25, 2010 | 07:26 PM
kierstyn's Avatar
Theres guys with alot more miles than that using 150 shot. With that said do a compression test and get all the things you need with the kit. Then spray the **** outa it! lol
Old Apr 25, 2010 | 07:35 PM
boosted LT1's Avatar
What do you mean by safe? Do you mean will it cause it to leak oil or burn oil? Well driving it 5 miles can do that, but juice increases hp and will be harder on the engine than babying it.
There are no free lunches the button can be fun and if you follow recommendations only if RPM >3000 and keep ~100hp or reduce timing it is only a little more dangerous than opening up a stock motor.
Old Apr 25, 2010 | 08:36 PM
96lt1m6's Avatar
Put a 150 and DRs on it and call it good
Old Apr 25, 2010 | 08:43 PM
xdanny510x's Avatar
im gonna spray mine and it has 196k ... Im gonna spray till it blow .. i already have a another engine waiting.. SO i say **** it and go for it!
Old Apr 25, 2010 | 10:33 PM
TravisMcGill2000's Avatar
My stock motor had 185k when i started spraying. I sprayed 150 shot on stock timing. Had a 255 fuel pump and colder plugs. I never had a problem with it. I pulled the motor out when it had 202k and it still look fine. ps the times in my sig. was on that motor.
Old Apr 25, 2010 | 10:35 PM
gregrob's Avatar
Nitrous? Yes. Nitrous.
Old Apr 26, 2010 | 01:40 AM
ale76051's Avatar
Thanks for the input
Old Apr 26, 2010 | 01:44 AM
ale76051's Avatar
But in that case which do y'all use a button or wot switch?
Old Apr 26, 2010 | 01:54 AM
gregrob's Avatar
WOT Switch, and window switch.
