1994 LT1 Opti Question
Old Apr 25, 2010 | 07:21 PM
1994 TA's Avatar
Default 1994 LT1 Opti Question
I replaced the opti cap and rotor with a MSD and now it will not run at idle??? It surges at about 1000 rpm's and you have to keep your foot on the gas to keep it running. Any suggestions on what could have went bad?? The battery has been disconnected for over a month. I also replaced the wires.
It surges and backfires????
Old Apr 25, 2010 | 07:26 PM
boosted LT1's Avatar
Hopefully you just miswired the plugs and have two crosswired. That is usually the case when you get a back fire. I would check the easiest side first and if you find two switched try starting it.
If once you get wires corrected it still has problems then it must be misinstalled. Let's hope for an easy fix and assume wires will fix it.
Good luck
Old Apr 25, 2010 | 07:28 PM
1994 TA's Avatar
Good luck
I pulled the firing order from SHBOX.com? But I will double check.
Thanks
Old Apr 25, 2010 | 10:00 PM
my1994z28's Avatar
Did you put lock tite on the rotor screws?They have a habit of vibrating loose.
Old Apr 25, 2010 | 10:17 PM
black93camaro's Avatar
i had that same problem im my 93 camaro. i took out the msd distributor about 20 times but it turned out it was only my coolant temp sensor. i would test/replace that first. it should only cost about $20 and so much easier to replace than to reinstall the msd
Old Apr 26, 2010 | 07:47 PM
1994 TA's Avatar
The one on the head or the one in the water pump? Because when I ran it to purge the system it would not warm up per the gauge???
Old Apr 26, 2010 | 08:20 PM
scj's Avatar
scj
one on the water pump
mine acted this way when i accidentally left it unplugged too.
Old Apr 26, 2010 | 10:32 PM
am_muscl's Avatar
did you actually take the opti off? If so, when you installed it, did you have to use any excessive force?
I had this same exact problem because some douche who installed my opti installed it wrong and it was just one tooth off. I'm talking the piece on the back of the opti that goes to the water pump.
Old Apr 26, 2010 | 11:14 PM
1994 TA's Avatar
Yes took it off. And no, it slid right on. Took probably an hour to find the sweet spot.
Old Apr 27, 2010 | 03:48 PM
1994 TA's Avatar
UPDATE!!! Found my issue after tearing the thing apart! I tore my intake elbow when reintalling it and it was sucking air before the MAF. I got it running and pushed in on the elbow to somewhat seal it and it ran without surging and flooding. Now I need to find a good elbow or just go cold air.
