Griffin rad users ?
Old Apr 26, 2010 | 05:20 PM
suicidal racing's Avatar
Default Griffin rad users ?
For the people using the griffin rad for the stand up deal..what are yall doing with your steam pipe vent tube and where are you tieing it in?
Im thinking seeing im deleteing my hvac ill tie it into the top hvac line on the water pump but im not sure if this will work,has anyone else tied into that spot.
I know the top tube is the return line on the pass side of the water pump and the bottom is the inlet tube..i was just going to freeze plug all 3 of them anyways but then i rememberd my steam pipe an started to think where to tie it in at and this seems like a good spot.
Old Apr 26, 2010 | 05:30 PM
1badzee's Avatar
A lot of people just have a nip welded on the radiator for the line (the way it is on our stockers).
Old Apr 26, 2010 | 05:41 PM
yeah i seen that already but im trying to dodge that seeing i would only use it for a couple months and then have to cap it seeing i wouldnt need it anymore..
i just did more research and it looks like people of still have hvac tie it into the T on the heater hose.So with that being said i could tie it into the top line on the water pump that is for the heater hose...
heres the direction of the flow for the heater core.
Old Apr 26, 2010 | 08:15 PM
Tapout911's Avatar
Yea I had a fitting added to the radiator for mine.
Old Apr 26, 2010 | 08:19 PM
yeah i seen yours in another thread..i think i seen where you said you had griffin weld the fittings for the upper and lower mount hoses..how much extra ddi that run you?
Old Apr 26, 2010 | 08:25 PM
Tapout911's Avatar
It was all the same price. They have to weld fitting regardless of hose or AN. If i remember it was like $330 to my door
Old Apr 26, 2010 | 08:56 PM
god damn..the griffin im getting is only 179$ from summit
http://www.summitracing.com/parts/GRI-1-25241-X/
